First Connection
- Re: First Connection
First Connection
13-03-2013 2:40 PM
Link Information
Uptime: 0 days, 0:11:11
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 448 / 17.225
Data Transferred (Sent/Received) [MB/MB]: 3,19 / 28,66
Output Power (Up/Down) [dBm]: 11,8 / 20,9
Line Attenuation (Up/Down) [dB]: 5,5 / 11,0
SN Margin (Up/Down) [dB]: 23,8 / 5,9
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 0 / 1
13-03-2013 3:24 PM
14-03-2013 12:02 PM
Is this likely to improve after the training period or do I need to get a different modem/router?
Was told the TG587N v2 I had was better then the TG582n, but wouldn't know what to get at a reasonable price.
14-03-2013 12:27 PM
Graham
14-03-2013 12:38 PM
Once the initial training period has completed, I'd be more than happy to take a look at things for you?
14-03-2013 12:57 PM
Would have preferred to use my TG587n v2 as it seemed to have better wireless signal but all the options to set it up mentioned my old ISP.
14-03-2013 1:18 PM
It's completely up to you of course, it can be added (takes 24 hours) and removed(further 24 hours) if you just wanted to try it
14-03-2013 1:40 PM
14-03-2013 2:26 PM
14-03-2013 2:33 PM
15-03-2013 8:55 PM
Quote from: Chris We can certainly get the upload speeds uncapped for you?
I assume the uncapping will happen after the training period?
15-03-2013 8:56 PM
18-03-2013 2:45 PM
We'll uncap it as soon as the phone order has completed, unfortunately we can't place any further orders while that's ongoing.
18-03-2013 2:59 PM
I should have posted earlier as Matt had seen an order there and wasn't aware it was an order I'd already placed for you!
Should all be sorted for you tomorrow morning
18-03-2013 3:33 PM
