Firmware upgrade
HaresEar
Firmware upgrade
Can some one push the latest firmware to my PN TG582n router please?  I do not have a working lan or windows PC to do it myself.
PS if not already done so can my upload speed be uncapped also?
Plusnet Alumni (retired) LinnPlusnet
Re: Firmware upgrade
Hi HaresEar,
I've arranged for the firmware to be pushed to your router now and this will take 10-15 minutes to complete. Please be aware that your router will not work during this time.
I'll check on your upload speed being uncapped as well. - EDIT: The order to uncap your upload has completed.
HaresEar
Cheers Linn  firmware upgrade completed.
HaresEar
Linn when was my upload uncapped as it has not changed according to my router or speed tests?
(Up/Down) [kbps/kbps]: 440 / 15.781
I've submitted an SNR reset on your line which should kick the uncap into effect. Your line was modified to uncap the upload, however, it looks like an SNR reset is required as well. This should take effect in the next 10-15 minutes.
HaresEar
Thanks Linn. All sorted.
H
