Firmware upgrade
- Re: Firmware upgrade
Firmware upgrade
13-08-2013 7:36 PM
I'd like to request my fibre router have the v10 version pushed to it if possible as it seems the upgrade tool i found on the forums dosnt work with this router and theres no web interface to upload a upgrade file to it.
Regards,
Chris
Regards,
Chris
Message 1 of 5
(830 Views)
4 REPLIES 4
13-08-2013 7:55 PM
I am not sure which one you found but this is the link I use http://products.plus-payh.co.uk/firmware/
However that assumes that you have the router with the USB port
Message 2 of 5
(372 Views)
13-08-2013 8:44 PM
Hi Oldjim,
Yup the link you posted is the one i used to download, the tool is a)not windows 7 compatible compatibility mode sorted that, b) the tool dosnt recognise the TG582n so are you saying the firmware can be put on a USB pen drive and upgrade from there?
Message 3 of 5
(372 Views)
13-08-2013 8:57 PM
No I am not - better wait for someone more knowledgeable to come along
Message 4 of 5
(372 Views)
13-08-2013 9:03 PM
Have you looked through this thread - http://community.plus.net/forum/index.php/topic,114824
and this particular post might help with W7 - http://community.plus.net/forum/index.php/topic,114824.msg988995.html#msg988995
Message 5 of 5
(372 Views)
