Firmware Upgrade - Locked Out
Glengavel
Hello,
I've been trying to upgrade the firmware on my TG582n, to version R10.2.2.9. The upgrade utility stated that the update had been succesful, but had been unable to restore the configuration. However, I now can't log in to the router - I've tried every combination of admin + admin, admin + serial number, admin + (blank), admin + (my password), Administrator + (blank), and all other combinations of Administrator + passwords that I can think of but to no avail. I've cycled the power off and on, but that didn't help. I haven't tried a 'factory reset' in case I lose Internet connectivity.
Any suggestions?
Fixes: 56
Re: Firmware Upgrade - Locked Out
I tried restoring a configuration from a previous version and it didn't like it. Needed a factory reset I'm afraid.
Fixes: 10
Plusnet applied the update for me via TR069 - first I knew was it rebooted (they told me they were going to do it and did so while I was trying to find out when!).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Glengavel
OK, got it. The password is the FULL serial number - I thought you had to knock off the initial two letters.
lowlatency
sorry to but in but I have the same router as you, can you tell me where you get the firmware upgrade fromas im on 8.4.4.J
thx Tongue
mushy
Are you on fibre or ADSL, 2 different versions for the TG582n
lowlatency
ADSL
dick:quote
apjashley1
Fixes: 10
I'd suggest the link given here is safer!
lowlatency
Ok thanks at the mo I have 8.4.4J
What is newer?
Thx in advanced
dick:quote
Fixes: 10
10.2.2.9 is the latest I'm aware of - there has been some confusion where a version number ending with B was merged with 10.2.2 to lead people to think there was a 10.2.2.B, but I've never actually seen an positive indication that this exists.
lowlatency
Ok thanks forthe reply so I will do the download later! will it wipe all the commands I used with telnet?
+ was the version I had a really old 1?
Cheesy
Fixes: 67
For ADSL 8.4.4.J is the version on currently supplied TG582n routers. So not particularly old.
David
apjashley1
I've used all three versions (8.4.4.J, 10.2.0.B, 10.2.2.9) and the original 8.4.4.J is the most stable. It's the only one not in beta!
Fixes: 10
I've not tried 10.2.0.9, but on 8.4.4.J on a 20CN exchange I was getting multiple unexplained sync drops per day. They stopped when PN upgraded me to 10.2.2.9. They also sent me a second router with 8.4.4.J (in case it was a hardware fault) - since my exchange was upgraded I've tried both and the 10.2.2.9 seems to give a better connection; the exchange attempted 3db (which was wrecked by the local electricity sub-station blowing up) on the new firmware where it hadn't tried that after a fortnight on the old.
