Firmware Update please
Photik
After doing everything I can manually to attempt a firmware change on my TG582n, it wont let me. Asking if possible for one of your guys can update to FTTC R10.2.5.2 EO please. Many thanks
Fixes: 163
Re: Firmware Update please
What's happening when you try to update this locally?
 Chris Parr
 Plusnet Staff
Photik
it only gets as far as trying to update through using the update software, then reclines to fall back and try again. then repeats
EDIT. 1st try fails to detect device..tells to go back
          2nd try detects, but fails the upgrade mode and start of firmware update...then repeats
Fixes: 163
Let me see if we can do it from here for you.
 Chris Parr
 Plusnet Staff
Fixes: 12
what benefits are there from updating to v10.x from v8.x ?
Photik
Thanks Chris. Done
