Firewall, Windows or Plusnet or both?
- Firewall, Windows or Plusnet or both?
13-08-2007 12:18 PM
I have Windows XP and have the built in firewall turned on.
I also have the Plusnet firewall selected to the "High" setting.
Can anyone tell me if this is the recommended arrangement?
I also have FSecure antivirus 2007.
Message 1 of 6
(3,208 Views)
5 REPLIES 5
Re: Firewall, Windows or Plusnet or both?
13-08-2007 12:49 PM
Only issue is based on using the XP firewall - it only reports on a limited number of incoming intrusions, plus anything that might be sending out won't get spotted.
Possible replacements include Zonealarm, Kerio or Sygate (All have freeware variants).
I tend to use Zonealarm www.zonealarm.com ; - choose the Basic (free) version.
Message 2 of 6
(700 Views)
13-08-2007 3:09 PM
I use PlusNet Firewall (set on medium), have a hard firewall in the router and use Kerio as a software firewall on my computer (Windows Firewall is switched off). I like the Kerio it's a free version with limited functions but it does enough for me and it is easy to use.
Message 3 of 6
(700 Views)
13-08-2007 4:32 PM
Following problems with my paid-for Internet Security suite firewall, I reverted to the Windows Vista firewall and have found that my computer is functioning much better. I have never had any difficulties with this, having used it in the past on XP, although I know that many people consider that a bi-directional firewall is best.
I also have my router firewall, but I hadn't realised that my F9 firewall was only set at low so I am grateful for your question because I have now reset it to high. I am happy to continue with this setup as I am a cautious Internet user.
Also, my computer is regularly updated with the Microsoft patches, has Defender and AVG, both updated.
However, I can see that a two-way firewall such as Zone Alarm would be better for someone people.
Message 4 of 6
(700 Views)
13-08-2007 5:08 PM
Quote from: poppy Following problems with my paid-for Internet Security suite firewall, I reverted to the Windows Vista firewall and have found that my computer is functioning much better. I have never had any difficulties with this, having used it in the past on XP, although I know that many people consider that a bi-directional firewall is best.
Vista's firewall is bi-directional.
Message 5 of 6
(700 Views)
13-08-2007 8:32 PM
Yes, I realise that the Vista firewall is bi-directional but as far as I know it has to be configured. I did find it (via Run/wf.msc) and tried to configure it once but must have got it wrong because being an amateur, it didn't operate correctly so I have left well alone. Have read the link - thank you for the information. Further advice welcome.
Message 6 of 6
(700 Views)
