Firbre (FTTC) broadband much slower than it should be
GlacialSpoon
I've noticed the line speed drop dramatically from over 50Mbps down to 19Mbps. I've tried all the usual tricks of restarting everything, testing using a wired connection to the router etc. etc. I so I believe it's a line issue. Nobody has got back to me after texting the HELP number to report a fault.
Please help. I would like to return to the minimum guaranteed speed noted as 55Mbps.
EDIT:
Having read some other posts I've now run the BTW test and attached the report which is MUCH WORSE than the speedtest.net result, reporting just 3.5Mbps!
I'm also using a NETGEAR Nighthawk(R) X4S R7800 on the latest firmware connected directly via ethernet to a PC.
Unfortunately we don't use our landline so I don't have a phone to do a quiet line test.
12 REPLIES 12
Fixes: 460
Re: Firbre (FTTC) broadband much slower than it should be
@GlacialSpoon  welcome to the forum
Report a fault:
For a problem with your broadband,
Text HELP followed by your landline number to 07800008121.
e.g. HELP 01234567891
(charges may apply at your standard rate)
  • We’ll run tests on your connection to find out what’s going on
  • If you need an engineer, we’ll text you in 15 mins to book a slot
  • If you don't need an engineer, our award-winning UK based support team will aim to call you within 30 mins to help sort the problem, though we're really busy at the moment, so this may be a little longer.
  • Service available Mon-Sun: 8am to 8pm
  • Outside of these hours please see our Help and Support guides, and if you’re still having trouble we’ll pick up your message when we’re open
If that doesn’t help then do come back and report.r
Fixes: 542
That's just a router, what are you using as the modem ?
GlacialSpoon
With respect @Baldrick1, did you read the part where I said I had already texted that HELP number and nobody is getting back to me? This is why I am here.
@MisterW Modem is an openreach box:
ECI Telecom Ltd.
Description: NGA ECI-CPE-MODEMS TYPE 1B
ECI Model: B-FOCUS V-2FUb/r Rev.B
Fixes: 542
Ok, AFAIK its not possible to get line stats from that modem.
Have you tried using the Plusnet supplied modem/router , I'm assuming its a Hub one ?
At least we could see some line stats from that...
GlacialSpoon
It's around here somewhere. I'll dig it out tonight, but I thought the supplied unit I have was just a router too. Will update when I find it.
Fixes: 542
Hmmm, If you've had FTTC for a few years then I suppose its possible that it is a TG582 , which doesnt have a VDSL compatible modem. Post back when you've found it.
GlacialSpoon
Hi @MisterW, turns out it was a Hub One. I rigged it up and found the attached screenshot of info. Is this what you need? Internet didn't seem to work at all through it though, even with the same settings I use on the Nighthawk, so I've reverted to the Nighthawk + Modem for now.
Shep41
Seasoned Pro
Fixes: 7
That screenshot is showing a downstream rate at 79meg. Could it be possible that the BT modem is failling
Fixes: 542
 @GlacialSpoon  yes, that's the Info.
Your sync speeds are pretty good , downstream is almost at the max 80Mb. Not quite sure why the Hub 1 would give no Internet access and assuming the Eci modem is syncing at similar speeds, why your throughput is so bad.
Did the Hub light go blue ?
Did you have to enter your username or was it already there ?
Fixes: 542
@GlacialSpoon  another thought ...
What does it say for 'Current line speed' iwhen you log in to the member centre ?
and do you have a static IP ?
GlacialSpoon
By jove I think we've got it!
@Shep41, you're suggestion seems to be bang on. I've futzed around with the Hub One for a while and now I've got an internet access running again and it tests at a lovely 72Mbps down now. The old openreach box is clearly dying or something.
@MisterW , the current line speed noted at 55 to 66Mbps but it seems I'm actually able to outpace that now.
Thanks to both for taking a look.
Now to reconfigure my network... eurgh.
Shep41
Seasoned Pro
Fixes: 7
We aim to please.🤣
