Finding an IP address of a friend on MSN......
barnsley1985
Can anyone advise me on how to find someone's, IP from simply chatting to them on MSN or similar...... I know used to be able to use netstat whilst a file is in transfer but, its seems this has been patched......
Any ideas ?
techguy
Re: Finding an IP address of a friend on MSN......
Why not just ask them to go to something like the thinkbroadband what's my IP tool http://www.thinkbroadband.com/ip.html
James
Or the easily remembered....
http://www.whatismyip.com
Fixes: 193
Or there is a program called Caller IP. It was on a Computer Shopper disc a couple of years back.
Forum Moderator and Customer
pierre_pierre
I an not sure if we have got the wrong, (or right) of the stick, is he trying to find some one elses ID
techguy
Hence the suggestions as I'm not right keen on using covert methods (I've never tried to and never would)
Bear in mind that messages are bounced off server clusters in the US so it is effectively a two leg journey (between you and the servers and then onward to the other party and vice versa)
Frequently, MSN will make a direct connection to the recipient if you are both available with a UPNP enabled NAT router.
If either of you are NATted and unable to open ports, it will use the server-based connection.
Thus, you can use NETSTAT to find out which computers you are connected to. Smiley
B.
techguy
Ah I've always been on a network or NAT router so have never seen it do that.
deadkenny
Another reason why I never enable UPnP. Seriously bad design when it comes to security.
techguy
uPnp and plug and play in general is a good idea in terms of usability for novices but there is always a tradeoff in security
