Fibre with ADSL port
greygit1
Re: Fibre with ADSL port
"and it is mounted upside down!"
Not necessarily.
Fixes: 334
Have another look at the picture, @greygit1 😀
Fixes: 459
@Anonymous wrote:
@jab1 wrote:
... but I'm intrigued as to why that is not an BT/OR socket.
It probably is a BT/OR master socket, but fitted with a possibly third party faceplate - I have several (but not that one)
From the size of it my suspicion is that it's an extension and the 'real' master socket is elsewhere in the property, possibly replaced by a junction box. I have used these on extensions in the past.
Fixes: 334
Could be, @Baldrick1 , but it should be easy to find the master socket - just locate where the drop-wire enters the property?
Fixes: 529
It is actually one of the VERY early BTOR attempts at a DSL faceplate. It was installed for early adopters of ADSL. I'm sure we had one in the office pre 21st century!
One of its problems is that the DSL port is actually an RJ45 rather than RJ11. An RJ11 plug, however, will fit the socket. Given its age my concern would be deteriation of the contact surfaces.
Fixes: 124
Looking at the picture I would be careful when taking the faceplate and the wall socket off the wall as it looks like paint might have stuck to both, I suggest using a Stanley knife (other makes are available) with a new blade and gently score around the edge of them
Further information on wall sockets and faceplates can be found here Guide for Openreach master socket
HTH
Fixes: 89
Is this the faceplate - taken from Kitz.co.uk
