Fibre switch
- Re: Fibre switch
Fibre switch
18-03-2012 4:50 PM
If you are using fibre for your broadband connection is there a facility to switch it off should you wish to use your computer disconnected from the internet ?
We are born into history and history is born into us.
Message 1 of 5
(1,323 Views)
4 REPLIES 4
Re: Fibre switch
18-03-2012 5:26 PM
If you are using wireless then go to wireless settings on the device and disconnect.
podman
podman
Message 2 of 5
(545 Views)
Re: Fibre switch
18-03-2012 11:35 PM
If your connection is wired then pull out the cable!!! lol
Message 3 of 5
(545 Views)
Re: Fibre switch
19-03-2012 2:25 PM
Sorry to be going on about this as I don't have fibre (but was considering getting it)
1. Is the fibre router connected to the master socket using a cable that could easily be unplugged
2. Can you confirm there is or is not an on/off switch on the fibre router.
Message 4 of 5
(545 Views)
Re: Fibre switch
19-03-2012 3:10 PM
With Fibre you have a Modem and a Router. If you do not require the internet then you can switch the modem off and with the router still on you will still have the LAN.
Message 5 of 5
(545 Views)
