Fibre still at old speed !
KJS
Hi, was all connected on tuesday am, upload is around 18mbs but download still at 7.5mb ish.
Had e mail this morning for the add on pro has been added !
Can this be manually switched to the faster download speed now please.
Keith
10 REPLIES 10
vultura
Re: Fibre still at old speed !
Sorry, do you mean Pro addon or you have upgraded to Fibre Extra?
Are you testing with a wired connection or wireless?
Has anyone seen my signature, it's gone missing.
KJS
Hi, fibre was fitted and connected on tues am.
The pro add on was on hold until the fibre had been confirmed as connected and then actioned today, hope that makes sense ?
Testing using wired connection.
Keith
adamwalker
Fixes: 221
hi I've just checked your account and everything seems to be in order there so I'm going to advise raising a fault: http://faults.plus.net
 Adam Walker
KJS
Hi all,
My bt test results
1. Best Effort Test:  -provides background information.
Download  Speed
7.3 Mbps
0 Mbps 0 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.3 Mbps
For your connection, the acceptable range of speeds is 12 Mbps-0 Mbps.
IP Profile for your line is - 77.44 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
6.64 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.64Mbps
Additional Information:
Adam, have raised a fault.
Keith
adamwalker
Fixes: 221
OK, I can see a fault report has been logged with our suppliers so we'll keep you up to date on ticket 62562462
 Adam Walker
KevinG
Quote from: KJS
Just to clarify, I hope you realise that the Pro add-on would not affect the download speed measured by any speed tester.
KJS
Kevin, Yes, thank you.
Keith
adamwalker
Fixes: 221
@KJS
FYI we've spotted an issue on your account which we've fixed and we hope this should allow you to connect now.
Please try rebooting the router and fingers crossed that should be you back online.
 Adam Walker
KJS
Adam, sorry just seen your reply, rebooted and see below !
chrispurvey
That looks a lot better!
If there's anything else then please let us know.
