Fibre speeds
davis36749
Fibre speeds
http://www.speedtest.net/my-result/3202476356
I need more speed!!!!    I'm virtually sat on my green cab.  my vdsl2 router sync's at 79984k and upload is at 19998 surely there is margin for more speed than my actual.  When with bt infinity a few years back I was getting 75mb and around 15mb up and was further away from the cab (previous address)
any help appreciated
David (davis36749)
davis36749
Fibre speeds
forgot to mention, using Gigabit ethernet all on wired connections hence the fantastic ping
jim:quote
Fixes: 60
Re: Fibre speeds
So what speeds are you getting
Re: Fibre speeds
Can't see anything on our side that'd be slowing it down, what does a BT speed test show? http://speedtest.btwholesale.com
