Fibre speeds
- Re: Fibre speeds
Fibre speeds
24-03-2014 8:22 PM
I am considering upgrading to fttc but I am unsure about the speeds. Currently I have a good adsl connection 18mb sync speed but when I look at fibre it says an estimated speed of 30mb I would of thought I could get more the that basing it on the adsl speed
Or does it not work the same way
Mark
Mark
Message 1 of 4
(940 Views)
3 REPLIES 3
Re: Fibre speeds
25-03-2014 12:13 PM
Hi Mark,
FTTC works a little differently to ADSL.
The distance between your FTTC Cabinet and your property is the main factor here. Ad FTTC uses a higher frequency it means that the speeds can drop considerably over quite a short distance.
More information on this can be found here: http://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance
Message 2 of 4
(346 Views)
Re: Fibre speeds
25-03-2014 9:25 PM
I see but I am only 0.5km from cabinet so 'should' get closer to 60 meg curiously I am actually closer to the exchange but due to the way the cabinets are laid out it is further away
Message 3 of 4
(346 Views)
Re: Fibre speeds
25-03-2014 10:42 PM
I am 600m from cab by both routes through our estate and I am on 30 ish so your 30 might be right.
I guess there must be a fair amount of extra cable hidden somewhere along the line to give me the speed I get when I compare it to the speeds on the link page.
podman
podman
Message 4 of 4
(346 Views)
