Fibre speeds gone downhill
- Re: Fibre speeds gone downhill
27-06-2014 10:52 PM
Can you check my speeds please on Fibre dropped from the high 60's download to 2.69 !!!!
<a href="http://www.speedtest.net/my-result/3590479432"><img src="http://www.speedtest.net/result/3590479432.png" /></a>
Message 1 of 6
(931 Views)
5 REPLIES 5
27-06-2014 11:01 PM
can you check my profile please as speed is now slower than previous ADSL
Message 2 of 6
(517 Views)
28-06-2014 9:50 AM
Message 3 of 6
(517 Views)
28-06-2014 9:54 AM
I have split off two posts you made in other persons threads and merged them to assist staff and added my own title
Are those speeds wired or wireless
Message 4 of 6
(517 Views)
28-06-2014 11:13 AM
Hi Jim
Wired connection, although this morning speed seems to have gone back to near normal speeds
<a href="http://www.speedtest.net/my-result/3591327733"><img src="http://www.speedtest.net/result/3591327733.png" /></a>
thanks
dick:quote
thanks
dick:quote
Message 5 of 6
(517 Views)
30-06-2014 11:07 AM
Your line seems to be passing all the tests that I can run.
If the issue persists, please raise a fault online at http://faults.plus.net and our Faults Team will investigate further.
Message 6 of 6
(517 Views)
