Fibre speed varying again,,,,again.
fp
I have been on unlimited fibre for a few months.
My speed is usually very good at 73 ish.
Periodically (at least when I measure it, which if quite often) it varies.  Tonight, after what appeared weeks of 73ish) it is between 34 and 70, even on consecutive tests.  And downloading an iso, the speed was varying by a factor of two - could be the providing site of course.
I raised a ticket a while back.  PN monitored the line for a few days and concluded everything was fine.
Should I expect the BT wholesale speed test to give such variable results.  Am I merely measuring contention/sharing/inadequate capacity.
All test are wired.
Fixes: 36
Re: Fibre speed varying again,,,,again.
Hi fp,
It looks like your connection has been down for some extended periods during the day.
<img src="http://community.plus.net/visualradius/generated/image14054148169705.png"/>
Is this anything you're aware of? i.e are you disconnecting delibarately? Would advise against that if you are.
Let me know either way so we can take things from there.
 Adam Walker
fp
I leave the BT modem switched on.
But turn the technicolor router off, when not needed.
(I thought from previous conversations this was acceptable - it being more important to leave the BT modem on.).
Fixes: 36
Not quite as the router manages the connection via the modem.
If you log into the router first then click the option to disconnect before powering off that should avoid DLM (dynamic line management) having adverse affects on speeds.
If you need any advice on how to do what I've mentioned just let us know.
 Adam Walker
fp
Thanks - I did not know this.
I guess to disconnect the router it is:
logon -> broadband connection -> internet : press disconnect button
Plusnet Alumni (retired) LinnPlusnet
Yes, fp, that's right.
Moving forward it may take some time for your speed to stabalize again if DLM has indeed kicked in due to the frequent disconnections. Let us know how you get on. Smiley
fp
The router (and BT modem) have been left on.
The pattern seems to be: 73ish except in the evenings when it varies between 30ish and 73ish; and varies between successive tests.
Am I just measuring the effect of contention at peak times?
All tests wired. BT wholesale speedtester mostly plus thinkbroadband tester and Ookla.
EDIT: 22:20 and I seem to be consistently around 20 - 40 Mbps.  Poor.
EDIT 06:30 back to consistent 73 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi fp,
Sorry for any confusion on my part here, I've just had a word with Adam about this.
A slight correction, your router can be powered off at any time without it affecting your speeds. With FTTC, the speeds are dictated by the uptime and error count at the Openreach Modem. As FTTC doesn't look at PPP session drops as part of this process, switching your router off should be absolutely fine.
If you're on ADSL, then the above responses do absolutely apply.
If your speeds drop again, can you please visit http://speedtest.btwholesale.com and run the initial Speed Test then click 'Further Diagnostics' and run the further test. Once complete, please provide a screenshot of your results on this thread and we'll investigate further.
Chris Pettitt
Cloud Environments Engineer
fp
Started today and this evening at 73.  Now 50-60 Mbps
screenshots attached.
Plusnet Staff
Plusnet Staff
Fixes: 5
Is this via Ethernet?
Chris Pettitt
fp
Yes - wired connection.
Currently back at 60 - 73
EDIT: 07:00 back to 73Mbps - see pictures.
Plusnet Staff
Plusnet Staff
Fixes: 5
I appreciate you don't have a Static IP but if you can keep your connection, could you please set up a TBB Graph so we can monitor?
http://community.plus.net/forum/index.php/topic,106312.0.html
Chris Pettitt
fp
I think I have done what you ask - picture attached.
What do you need me to do: leave the router for a few days and then post the picture?
Speeds currently good at 73
Everything wired.
Terranova667
FP you haven't posted your TBB graph instead you have posted the example one that TBB give.
fp
Oops - thanks.  Since the one attached seems to be for my IP and is all red and I am getting 73 Mbps at the moment, I guess something is not setup correctly.
OK I have enabled ping :-)
