Fibre speed varying again,,,,again.
- Fibre speed varying again,,,,again.
14-07-2014 9:26 PM
My speed is usually very good at 73 ish.
Periodically (at least when I measure it, which if quite often) it varies. Tonight, after what appeared weeks of 73ish) it is between 34 and 70, even on consecutive tests. And downloading an iso, the speed was varying by a factor of two - could be the providing site of course.
I raised a ticket a while back. PN monitored the line for a few days and concluded everything was fine.
Should I expect the BT wholesale speed test to give such variable results. Am I merely measuring contention/sharing/inadequate capacity.
All test are wired.
Re: Fibre speed varying again,,,,again.
15-07-2014 10:01 AM
It looks like your connection has been down for some extended periods during the day.
<img src="http://community.plus.net/visualradius/generated/image14054148169705.png"/>
Is this anything you're aware of? i.e are you disconnecting delibarately? Would advise against that if you are.
Let me know either way so we can take things from there.
15-07-2014 6:43 PM
But turn the technicolor router off, when not needed.
(I thought from previous conversations this was acceptable - it being more important to leave the BT modem on.).
16-07-2014 12:26 PM
Not quite as the router manages the connection via the modem.
If you log into the router first then click the option to disconnect before powering off that should avoid DLM (dynamic line management) having adverse affects on speeds.
If you need any advice on how to do what I've mentioned just let us know.
16-07-2014 7:12 PM
I guess to disconnect the router it is:
logon -> broadband connection -> internet : press disconnect button
17-07-2014 9:16 AM
Moving forward it may take some time for your speed to stabalize again if DLM has indeed kicked in due to the frequent disconnections. Let us know how you get on.
22-07-2014 9:12 PM
The pattern seems to be: 73ish except in the evenings when it varies between 30ish and 73ish; and varies between successive tests.
Am I just measuring the effect of contention at peak times?
All tests wired. BT wholesale speedtester mostly plus thinkbroadband tester and Ookla.
EDIT: 22:20 and I seem to be consistently around 20 - 40 Mbps. Poor.
EDIT 06:30 back to consistent 73 Mbps
23-07-2014 9:50 AM
Sorry for any confusion on my part here, I've just had a word with Adam about this.
A slight correction, your router can be powered off at any time without it affecting your speeds. With FTTC, the speeds are dictated by the uptime and error count at the Openreach Modem. As FTTC doesn't look at PPP session drops as part of this process, switching your router off should be absolutely fine.
If you're on ADSL, then the above responses do absolutely apply.
If your speeds drop again, can you please visit http://speedtest.btwholesale.com and run the initial Speed Test then click 'Further Diagnostics' and run the further test. Once complete, please provide a screenshot of your results on this thread and we'll investigate further.
23-07-2014 10:10 PM
screenshots attached.
23-07-2014 10:19 PM
23-07-2014 10:30 PM
Currently back at 60 - 73
EDIT: 07:00 back to 73Mbps - see pictures.
24-07-2014 9:05 AM
http://community.plus.net/forum/index.php/topic,106312.0.html
24-07-2014 7:10 PM
What do you need me to do: leave the router for a few days and then post the picture?
Speeds currently good at 73
Everything wired.
24-07-2014 7:27 PM
24-07-2014 7:47 PM
OK I have enabled ping 🙂
