Fibre speed increase
- Fibre speed increase
03-12-2013 11:54 AM
Quick question, i have just checked on the connection page on my Members centre page, and have noticed that my Estimated Line speed has increased to 59Mb, but i am currently not receiving this, as you can see my Current line speed is 52.8Mb, i have powered down both router and Modem to no avail, is it a case of a call to PN to re-profile my line or will this happen over a few days.
Overall i am more than happy with service from PN.
Phone exchange:
HETTON LE HOLE
Estimated line speed:
59Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-12-03 11:37:15
Current line speed:
52.8 Mb
Phone exchange:
HETTON LE HOLE
Current line speed:
52.8 Mb
Message 1 of 4
(839 Views)
3 REPLIES 3
Re: Fibre speed increase
03-12-2013 2:21 PM
Reprofiling the line isn't something simple on a Fibre line. It can only be reset after an engineers visit, we simply don't have the tools to do anything with this.
You may see the line speed improve, however the line management on Fibre can't take a while to do this. If your speed is significantly under your estimate then we can possibly look into this as a fault if you report it at https://faults.plus.net
Message 2 of 4
(439 Views)
03-12-2013 7:49 PM
My original speed estimate was 57Mb down but according to the btwholesale checker this has now increased
FAQ
1. Best Effort Test: -provides background information.
Download Speed
58.54 Mbps
0 Mbps 60.83 Mbps
Max Achievable Speed
Download speedachieved during the test was - 58.54 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-60.83 Mbps .
Additional Information:
IP Profile for your line is - 60.83 Mbps
Upload Speed
10.31 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 10.31Mbps
FAQ
Download Speed
58.54 Mbps
0 Mbps 60.83 Mbps
Upload Speed
10.31 Mbps
0 Mbps 20 Mbps
Message 3 of 4
(439 Views)
03-12-2013 11:03 PM
Chris, thanks for that, i'll leave this for now, and monitor over a period of time, i dont want to log as a fault, as up to now my bband experience with PN has been excellent.
Message 4 of 4
(439 Views)
