Fibre - replace Technicolor with Airport Express?
- Re: Fibre - replace Technicolor with Airport Expre...
24-08-2014 3:42 PM
I have Plusnet Fibre and hate the Technicolor Router supplied as the wifi performance is just terrible. Is it possible to buy an Apple Airport Express or the Extreme and replace the Technicolor router with this? So i would just have the BT fibre box and then connect the Apple Airport to that?
Matt
Matt
Message 1 of 6
(1,377 Views)
5 REPLIES 5
Re: Fibre - replace Technicolor with Airport Express?
24-08-2014 4:01 PM
I've got an extreme and it worked fine as a replacement for the pn supplied one.
Message 2 of 6
(735 Views)
24-08-2014 7:50 PM
Was it just a case of plugging it in or was there big configuration?
Message 3 of 6
(735 Views)
24-08-2014 9:13 PM
you need to change some config using Airport Utility but it's pretty straight forward.
Message 4 of 6
(735 Views)
28-01-2015 12:16 PM
Hey, Im trying to do this. But of course its not working. Any chance you could outline some of the settings you changed or point me in the direction you found them.
Message 5 of 6
(735 Views)
28-01-2015 1:12 PM
Oh god worked out my username was wrong .. All working fine .. And buy what and improvement!!
Message 6 of 6
(735 Views)
