Fibre profile update
edpgc
Current line speed:
78 Mb
BT Wholesale says
Download Speed  61.51 Mbps
Max Achievable Speed 63.83 Mbps
Could you check/nudge my IP profile.  Thanks.
1 REPLY
Re: Fibre profile update
Hi edpgc,
Welcome to the community forums.
The current line speed that you referred to above is your profile on our systems and not your current sync speed.
If you check again you'll see that this has now changed according to your sync speed, a similar speed to your download speed.
