Fibre profile reset
- Re: Fibre profile reset
Fibre profile reset
02-12-2013 9:48 PM
my fibre profile needs a reset i am lost 10mb of download speed since swiched over
Message 1 of 7
(1,092 Views)
6 REPLIES 6
03-12-2013 10:03 AM
ISPs don't have the ability to easily reset a line on Fibre, at the moment this only happens via an engineer visit or by the DLM automatically. If you've lost speed and it's enough to warrant a fault, then report this through to us and we'll take a look.
Message 2 of 7
(506 Views)
04-12-2013 12:28 PM
my speeds have gone down upload and download speed lost from upload 18mb to 13 mb from 72mb download to 62mb i had 72mb from bt when i was with them all the time with plusnet it loss speed the ping was 17 after the swich now it gone up to 30 do you think a DLM automatically make the change?
Message 3 of 7
(506 Views)
04-12-2013 9:21 PM
i did chack the bt broadband checker and it come out as 80mb download and 20mb upload why is it lossing speed
Message 4 of 7
(506 Views)
05-12-2013 6:32 PM
can we put a DLM on my broadband i know it can be faster as it is
Message 5 of 7
(506 Views)
09-12-2013 10:28 AM
As mentioned earlier, we have very little direct control over Fibre connections. All of them do have DLM on though as per Kelly's reply in your other thread on the same subject: http://community.plus.net/forum/index.php/topic,120954.msg1048476.html#msg1048476
Message 6 of 7
(506 Views)
09-12-2013 10:34 AM
I believe in a few months time, ISPs will have more control over fibre connections?
Message 7 of 7
(506 Views)
