Fibre keeps disconnecting over the last few days
LindaC123
Since around 2 or 3 days ago our fibre has been disconnecting multiple times a day. I’ve done the usual checks, quiet line test and got the filter in the master socket and it still continues. I work from home and it’s starting to get in the way of that. Is there any way to fix this?
6 REPLIES 6
Legend
Fixes: 257
Re: Fibre keeps disconnecting over the last few days
@LindaC123 Quickest way is probably to raise a fault via https://www.plus.net/help/report-a-problem/broadband/
LindaC123
I’ve sent them the text but heard nothing back in a few hours.
Legend
Fixes: 257
It may take a while - if you have heard nothing by tomorrow morning , post back and I have a back-up plan.
willcutforth
Fixes: 99
Hey there @LindaC123 is this still happening? If so, I can investigate!
 Will Cutforth
LindaC123
It's fine now, thanks
willcutforth
Fixes: 99
Awesome, glad to hear it! You know where we are if you need us! Smiley
 Will Cutforth
