Fibre installation question.
buseng12
I have just booked an upgrade to fibre with the appointment arranged for next Monday (24th).
My question is that I am using a BT HH5 which as you know already has a fibre modem built in. I am wondering what the engineer will do, still install an Openreach modem or connect straight to my HH5?
The idea being having as much less "clutter" & wiring as possible.
Cheers.
Fixes: 62
Re: Fibre installation question.
He will install the BT Modem to make sure it is working and then you can replace it with the HH5 after he has gone
buseng12
Thanks, no problem. Will do that. Also be able to see any speed differences between the two.
Fixes: 62
Let us know how you get on with that.
 Adam Walker
