Fibre extension kit
rsinbad
Fibre extension kit
Apologies if this issue has been raised before.
I am shortly to be connected to unlimited fibre, with the order comes  a fibre extension kit which I understand can be x meters from the bt Socket. Currently I have a filter atached to the master socket to feed my telephone and router. I plan to have the extension routed to the living room instead of the front lobby, does plusnet have a diagram of this with + cables required etc .
Regards
rsinbad
Re: Fibre extension kit
Ok managed to solve this problem
Dmitchell
Hey rsinbad.
Glad to hear you now have this sorted. A fibre extension kit that the engineers we send out would supply a 30m CAT5e cable (Ethernet). That's all it is, this is simply to extend the range between the router and Openreach Modem.
Hope this helps.
Dean
