Fibre estimated at 64Mb, only receiving 9Mb
- Re: Fibre estimated at 64Mb, only receiving 9Mb
30-10-2013 1:34 PM
New customer with Plusnet, and my Unlimited Fibre was installed a couple of days ago and I have not seen any speeds above 9Mb, is there a period of time for the speeds to increase, or should I have the maximum from day 1?
I've tried a wired & wireless connection and various speed test sites, even test downloading actual files (thinkbroadband.co.uk speedtest) and a 1GB file takes 15 minutes to download. A friend who live on the other side of the country using BT Fibre downloads the same file in under 3 minutes.
The profile on the Plusnet site says that my current line speed is 78Mb, but I don't see any of that. I have not tried restarting the FTTC modem or router as I don't want to interfere with the 10 day training period.
Could somebody from Plusnet please have a look and see if anything shows up on their side?
Thanks,
Gavin
Thanks,
Gavin
Message 1 of 6
(1,416 Views)
5 REPLIES 5
30-10-2013 1:58 PM
10 day training period...but mine was similar for first couple days, down at 7.7Mbps then jumped up to estimated speeds.
Message 2 of 6
(755 Views)
30-10-2013 2:07 PM
This a myth - There is no 10 day training period for FTTC
http://forum.kitz.co.uk/index.php?topic=10513.0
Message 3 of 6
(755 Views)
30-10-2013 2:16 PM
Run the BT speed test. When the first pass completes run the Further Diagnostics (button at the bottom) and post back the full information that provides please.
Message 4 of 6
(755 Views)
30-10-2013 6:44 PM
Thanks everyone,
When I got home I tried running the BT Speedtest, and it reported the download as 9Mb/s and the upload as 8Mb/s, I started the further test, and sure enough it reported the same as well as my line profile of 71Mb/s. Stupidly I did not copy the results I just clicked to start the next test, this meant changing the username of the login to the BT speedtest one. I did this but when I went to start the next test it kept coming up with DNS problems and wouldn't connect to the webpage/Tap3 test. I changed the router username and password back to the Plus.net one and tried to get my router to reconnect to the Internet. I got stuck in a loop and wouldn't connect, end results is that I unplugged and replugged the router and FTTC modem. When they came back up straight away I noticed the Lan1 LED on the FTTC modem flashing a lot quicker, andsure enough running the BT Speedtest again I now get 69Mb/s download and 18Mb/s upload
I've tried to get to that Test2 of the BT Speedtest, but everytime I put in my phone number it keeps trying to run test3/Tap3, and it refuses to run when I change the router login to what is recommended, DNS Errors!
But I'm happy for the moment, I didn't want to unplug and replug stuff because I was worried about the 'training period', thanks for confirming it is all a myth.
I should have tried power cycling the router and modem anyway before posting.
Thanks.
Thanks.
Message 5 of 6
(755 Views)
30-10-2013 7:56 PM
rebooting the router probably updated the Plusnet profile as shown here https://portal.plus.net/my.html?action=data_transfer_speed
Message 6 of 6
(755 Views)
