Fibre connection setup – questions
- Fibre connection setup – questions
- « Previous
- 1
- 2
- Next »
Re: Fibre connection setup – questions
18-05-2011 5:32 PM
Looks like my setup will be RJ11 cable from the master socket to the modem ( will hopefully fasten on wall in the hall) and then use the RJ45 cable I already have from the hall to the study to the router.
Just one piece I do not understand – RJ11 cable is basically telephone wire. Assume the new fitting on the master socket caters for the RJ11 connection and there is also another slot for the ordinary telephone connection.
Does that sound right?
18-05-2011 5:37 PM
Keeping the modem close to the master is the best way to go performance wise
There have been a few reports about the BT modem failing, mostly associated with running hot.
So if you can get the BT engineer to install and power that up first...
18-05-2011 5:52 PM
I can now get my head around it and understand the process. The hour or so on the forum has proved above expectation - thanks to all for the help received.
18-05-2011 6:08 PM
Mine ran much too warm for my liking when I first got it, since mounting it vertically on the side of a cupboard it is much cooler.
Quote from: knowdice There have been a few reports about the BT modem failing, mostly associated with running hot.
18-05-2011 8:09 PM
Will report back once the engineer has been... next Wednesday.
19-05-2011 3:24 PM
25-05-2011 11:07 AM
What BT have actually done is install a new master socket where my extension socket was, and have rewired the old master socket so that it simply connects their incoming line to my old extension wiring. They then tested and said that I was getting the full rate available.
So I don't need, and didn't get, a data extension cable. But I now believe that a data extension cable is nothing more than a normal telephone extension cable with RJ11 connectors on each end; it is a flat cable that isn't even twisted pair.
25-05-2011 11:26 AM
Mathew
25-05-2011 11:37 AM
Quote from: KevinG No, they don't relocate the master socket, they can provide a data extension kit to locate the modem up to 30m from it.
No they don't I requested one, one wasn't brought.
Apprently they have none in the country.
Engineers words not mine.
25-05-2011 12:20 PM
25-05-2011 12:34 PM
Forgive the pedantry but can you be a more specific as there's no such thing as an 'ethernet cable' or an 'RJ11 cable'. The ambiguity could lead to different interpretations over what you are actually trying to say.
Mathew
25-05-2011 1:07 PM
Not sure that wireless solutions exist. We are talking here about the data (extension) cables that go from Master socket to BT Fibre modem. Which I strongly suspect are no more than a conventional telephone extension cable with conventional RJ11 plugs on the end.
As it happens, I have already replaced the fairly short cable that is provided as standard with one about twice the length as that allows me to position the modem slightly more conveniently. I'd actually prefer to use a longer cable still; I don't own any longer cables with RJ11 plugs so may well make my own using Cat5.
As a curious sidenote, as BT are now using MY extension cable to get the outside line to the new master socket, presumably I now can't touch it i.e. it has become THEIRS. Which would also mean they are responsible for it...
25-05-2011 7:20 PM
Pleased it all worked out.
As a matter of interest which router did you use – was the supplied Netgear or your Billion 7800n. And how was it get it going OK.
25-05-2011 8:55 PM
I used my own Billion 7800N. The supplied Netgear is still in its shrinkwrap.
I've added exactly what I did to another thread: http://community.plus.net/forum/index.php/topic,94917.0.html . If you have a Billion and want even more detail I have screenshots that I can send you (once I've edited my connection details out). Ask if you need any guidance.
25-05-2011 9:13 PM
Yet to get to the ordering stage but will soon.
The info is spot on and will be very helpful - thanks.
- « Previous
- 1
- 2
- Next »
