Fibre connection dropouts and packet loss
- Re: Fibre connection dropouts and packet loss
10-01-2014 11:52 PM
My router (an Asus RT-N66U running the latest Asus firmware) logs show:
Jan 10 22:56:06 pppd[338]: No response to 10 echo-requests
Jan 10 22:56:06 pppd[338]: Serial link appears to be disconnected.
Jan 10 22:56:06 pppd[338]: Connect time 21.9 minutes.
Jan 10 22:56:06 pppd[338]: Sent 6837419 bytes, received 18776994 bytes.
Jan 10 22:56:06 dnsmasq[300]: read /etc/hosts - 5 addresses
Jan 10 22:56:06 dnsmasq-dhcp[300]: read /etc/ethers - 3 addresses
Jan 10 22:56:06 dnsmasq[300]: using nameserver 212.159.6.10#53
Jan 10 22:56:06 dnsmasq[300]: using nameserver 212.159.6.9#53
Jan 10 22:56:09 WAN Connection: Fail to connect with some issues.
Jan 10 22:56:09 stop_nat_rules: apply the redirect_rules!
Jan 10 22:56:12 pppd[338]: Connection terminated.
Jan 10 22:56:13 pppd[338]: Sent PADT
Jan 10 22:56:13 pppd[338]: Modem hangup
Jan 10 22:56:20 dnsmasq-dhcp[300]: DHCPINFORM(br0) 192.168.1.150 10:bf:48:fb:6c:28
Jan 10 22:56:20 dnsmasq-dhcp[300]: DHCPACK(br0) 192.168.1.150 10:bf:48:fb:6c:28 i5PC
Jan 10 22:56:58 pppd[338]: Timeout waiting for PADO packets
I always get the same message - the connect time varies hugely but over the last few days I have seen anywhere between 3 and 472 minutes.
Rebooting the OpenReach modem or the router have little or no effect, the WiFi will remain connected the entire time and windows will ask for additional login information for the PPPoE connection, this additional information is unnecessary as it's already stored in the router. Attempts to manually reconnect the PPPoE connection via the router achieve nothing (resulting in the router throwing an error saying 'connection timeout ').
Connect time for the previous session (whilst I was writing this post) was 37.1 minutes.
Any help with this issue would be greatly appreciated.
Thanks,
Neil.
12-01-2014 4:23 PM
After that lovely twelve hours of solid connection, I went back to a substantially more unstable and less usable connection. Up-time and down-time varied hugely but between 3.30am and 11.00am I was exceptionally lucky to see 20 minutes between disconnects. In reality the sustained connection times were more between 3 and 5 minutes.
I am beginning to see dropping of connection without anything being logged in my router. Some of these quicker drops reconnect almost instantly but are enough to temporarily interrupt online gaming or media playback through things like the iPlayer. These are present alongside the modem hangups which are still a persistent issue.
My job for today is to investigate the noise on the phone line - the gentleman on the phone suggested connecting to the test socket. I will do that and if nothing has changed I was told to call PlusNet back.
13-01-2014 2:00 PM
13-01-2014 10:33 PM
Whilst on hold waiting for a PlusNet representative the hiss was drowning out medium to quiet bits in the music. Am I wrong in my assumption that this amount of noise should show in SNR statistics on the modem? Is there anyway I can access those statistics in future on the provided openreach modem?
14-01-2014 1:10 PM
Either way though he'll be able to get things sorted for you.
27-01-2014 11:31 AM
27-01-2014 3:59 PM
27-01-2014 5:18 PM
http://www.speedtest.net/my-result/3262873020
Ping checking seems to have failed on this test inexplicably.
27-01-2014 5:19 PM
27-01-2014 5:50 PM
28-01-2014 9:20 AM
