Fibre: can I switch it off?
- Re: Fibre: can I switch it off?
03-08-2011 8:53 AM
I think I'm correct in saying that if I'm away for a few days I can turn my router off without a subsequent hit to my speed. Is this right?
And can I turn off the fibre modem too?
TIA!
TIA!
Message 1 of 4
(767 Views)
3 REPLIES 3
03-08-2011 10:03 AM
You **SHOULD** be perfectly fine to safely disconnect,
Connect to the bipac, let it disconnect the session, let the modem "relax" (stop flashing, mine seems to take 2-5 seconds after the bipac says im disconnected) then whap off the power.
Should be hunky dory i wouldnt recommend doing it daily, but if its off for a few days i think you should be fine
Regards
Regards
Message 2 of 4
(442 Views)
03-08-2011 10:18 AM
Message 3 of 4
(442 Views)
03-08-2011 10:51 AM
Cool. Thanks folks.
I sometimes turn the router off overnight, though the modem stays on. But for longer absences they are both going off.
Message 4 of 4
(442 Views)
