Fibre broadband upgrade
andres
I'm considering an upgrade to fibre broadband - mostly to be able to increase the amount of download that I can do.
A few questions:
-I currently have a fixed ip. Would I be able to still have a fixed ip with the fiber connection?
-I am planning to put a small LAMP server behind - are there any contraindications?
-I'm currently using a Thomson TG784. Looks like it can be used instead of the Plusnet modem + router combo - is my research correct?
Thanks in advance,
    Andres
7 REPLIES 7
Fixes: 392
Re: Fibre broadband upgrade
You will still need to use the OpenReach supplied modem. The TG784 does have an Ethernet WAN port which you can connect to the modem instead of the normal PlusNet router.
chrispurvey
Depending on which fibre package you chose you would be able to keep your static IP, this is only available on the fibre Extra package.
There should be no issues using a LAMP server, as MisterW mentioned, you would still need to use the Openreach modem but you could still use your TG784 router.
I hope this helps, if you've got any other questions please ask.
Chris
Fixes: 392
Chris, I understood that the situation was that if you already had a static IP you could retain it ( and other things such as webspace,free domain etc ) when changing packages irrespective of the new package. Is that not correct anymore ?
Oldjim
Resting Legend
Fixes: 63
Not when moving to fibre - I remember this coming up a while back but I can't remember the reasoning
Fixes: 392
You're not wrong Jim  Sad  http://community.plus.net/forum/index.php/topic,102383.0.html
chrispurvey
The thread is where I was going to link to, I was just looking for it.
andres
Thanks everyone - hopefully now I have all the info I need!
  Andres
