Fibre broadband connection without the router
brunoschwartz
Hello All,
I am a new customer, migrated today from bethere. With bethere I had a static IP and the router set to bridge mode.
Now that I have a dedicated modem, I wonder can I just leave the Technicolor TG582n router out of the equation and connect my linux gateway directly tothe modem. The linux comp is connecting a small LAN to the internet. One problem I envisage, it seems I still have to supply the login/pass credentials, where will I enter them then? Thanks for any thoughts.
BW,
B
Fixes: 62
Re: Fibre broadband connection without the router
PeeGee
"Roaring Penguin" (or probably "rp-pppoe" in the repo) will handle the connection. Google for configuration if the man pages are inadequate Wink
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
brunoschwartz
Thanks both.
pppoeconf is the package so install for debian based distros (btw it uses rp-pppoe). The standard settings were fine for me and the install script takes one through them.
PeeGee
Great, that's something to file away in case I need it later on Wink Cheesy
