Fibre broadband..... Flashing green dsl light.
lxkid
I started having this error every now and then on my normal broadband , it would go off for a day or two then would be ok for at least a month then happen again. I put this down to a fault with the router I had at the time.
I've upgraded to plusnet fibre now since last month, so I assumed everything would be ok, till wk before last when the green dsl was flashing it came back on the next day. So I woke up yesterday morning to find the dsl light flashing yet again...as of yet has still not come on!
Any suggestion? Thinking it may be a fault with my line.
Regards
NorthEasterner
Re: Fibre broadband..... Flashing green dsl light.
Don't be confused with the LAN 1 light as that is supposed to flash.
Try opening a faults ticket and Plusnet will run a test etc..  And if there is something wrong, a engineers visit maybe required.
Jamie
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 21
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls?
myjess
See my thread on dsl issue. Are you anywhere near me?
lxkid
I've raised a ticket.. I've had this problem for well over 2 years now, like I said before I was guessing the fault was with my old router so I stuck with it till I could buy a new one, but since the the 1st of last month I've upgraded to fibre and got all new equipment so I can rule the old router fault out.
My phone line seems to be completely off... Think that's down to plusnet running test.
My area code is bs23.
Fixes: 21
The full line test lasts around 3 - 3½ minutes maximum usually.
There don't seem to be any widespread reported problems in W-S-M (01934) so it probably is your own line  Sad
lxkid
I'm also thinking it could be a fault with my line  Undecided ... considering its been going on for 2 years, no-one in my street have reported having the same issues I've been having.
let's see how prompt openreach are at fixing my fault.
Fixes: 21
The tests have got to find one first, Intermittent faults can be a right sod to detect Huh  Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls?
lxkid
I can't recall hearing hearing anything out of the ordinary while I've been on my house phone. looks like I'm going to be stuck with this fault for awhile then Undecided this has been the longest the dsl light has been flashing for be the 3rd day today, when it used to happen before it would magically switch back on the following day and be great for a month or so till it decides to play up again.
Fixes: 21
Hopefully a line test may find something then if it's persisting, fingers crossed.
lxkid
I should add( for the other people reading this or people wanting to switch to plusnet) that the plusnet service over the past 3 years I have been with them have been exceptional , I do not hold plusnet responsible for the fault , its just one of those things!
I will be over the moon when it's finally resolved  Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi lxkid,
I'm sorry to hear that you're having problems with your connection.
If you've raised a support ticket with us at http://faults.plus.net we would be more than happy to take a look into things for you.
Chris Pettitt
Cloud Environments Engineer
lxkid
I raised a fault ticket yesterday afternoon around 14:00pm, just waiting to hear back from them.
I can see your line has been tested and our faults team will be in-touch with the outcome.
lxkid
Thank you, be great to finally hear what the fault is, and how long before I get my Internet back and running Grin
