Fibre available ???
waynem
Fibre available ???
Hi
could someone from Plusnet please confirm that i am now able to order Fibre , acording to BT wholesale etc it says its now available , if i go to change product it comes up in the options panel  Smiley ..
if this is the case how long will it take to change over etc
cheers
Fixes: 9
Re: Fibre available ???
If it says it is available when you put your phone number in to http://www.dslchecker.bt.com/adsl/adslchecker.welcome it is definitely available.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
waynem
Thanks jelv
top line in the checker thing is this  (WBC FTTC Up to 80 Up to 20 -- Available )
which is great .. so can i just do a product change in my account ?
thanks
Fixes: 126
yes you can Smiley
Will Moderate For Thanks
waynem
Thanks dvorak ..
one for Plusnet  i think
million dollar question .. how long will it take to sort ?
an they made a real mess of my first order so is there anything i can do to make it go a little smoother ?
cheers
Oh an alittle off topic this ... but are there any plans for a TV  type package or is there already one available ?
Fixes: 9
How long will depend upon OpenRetch engineer availability in your area. You will probably only find out when you place the order.
There's no plans for a TV package; this has been confirmed in a Plusnet posting on here quite recently.
Fixes: 126
yeah, when you go through the upgrade you'll get a choice of appointments.
waynem
Thanks Guys  Grin
DrDave
It really is painless - well it was in my case.  Smiley
waynem
Ordered  Smiley
pint
My local exchange is on the fibre roll out list mentioned in the comunity story here http://community.plus.net/blog/2013/02/14/is-plusnet-fibre-coming-to-a-cabinet-near-you/
However im not/my exchange isnot  in a plusnet low cost area, so plusnets fibre offering at the moment looks to be quite expensive.
It will be intersting to see how plusnets market 1 /high cost area prices compare with the oter LLU options and providers that are available on my exchange.
