Fibre available now ??
- Re: Fibre available now ??
07-09-2014 9:21 AM
But there is no option to upgrade my account here on Plusnet atm....
Can someone confirm fibre is available ?
Cheers, Rob.
07-09-2014 9:48 AM
07-09-2014 10:11 AM
This is the checker result for my number but although the exchange is fibre enabled, I'm not sure whether the cabinet is.
The checker shows WBC ADSL2+ with download speeds of 2.5 to 6.5.
I assume it would say FTTC if it was.
Although I live in a town it's like living in the sticks with even an average mobile signal of -107dDm or an absolute maximum of
-99dBm on a good day.
07-09-2014 10:24 AM
The checker will tell you which cabinet you're connected to and it should give an estimated date for FTTC (if your cabinet is due to be upgraded in the next couple of months).
07-09-2014 10:30 AM
07-09-2014 10:39 AM
07-09-2014 11:06 AM
I'm happy with the service we're getting from Plusnet & the ADSL speeds which are 4.5 down & 0.89 up & are very stable.
07-09-2014 11:34 AM
07-09-2014 1:58 PM
08-09-2014 9:49 AM
Thanks for the info guys.
