Fibre and Pro Add-On
Discord
I've noticed I'm still paying £5pm for the pro addon.  Is this really worth it?
Connection is mainly used for gaming, with a bit of streaming etc..  Does the pro package still prioritise the line for gaming to ensure low pings?
Fixes: 62
Re: Fibre and Pro Add-On
If you are on unlimited it is a waste of money
If you are on Essentials it may be worth it
http://www.plus.net/support/broadband/speed_guide/traffic_management.shtml
In neither case will it affect pings
Fixes: 78
@Discord
Let us know if you do want to try using the connection without the pro add-on or if there's any specific issues you might have noticed.
Adam
 Adam Walker
