Fibre Usage Limit?
active8
Fibre Usage Limit?
Hello,
I was wondering if there is a Fibre Usage Limit as my Fibre usage has been fairly high, probably a bit too high. Just wondering if Im likely to be put on the 'bad boys pipe' like what happened to 240 users back in 2004.
Cheers
Fixes: 62
Re: Fibre Usage Limit?
no there isn't and no you won't be
active8
I hit 600gb so was a little concerned
Fixes: 258
that all? Wink
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
active8
thats ok then?
Fixes: 21
No problems, it is fully unlimited.
I regularly use 500Gb+
