Fibre Unlimited Speed crashed from 50 Mbps to 12Mbps
- Fibre Unlimited Speed crashed from 50 Mbps to 12Mb...
13-02-2013 10:31 PM
Download speedachieved during the test was - 11.79 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-53.49 Mbps .
Additional Information:
IP Profile for your line is - 53.49 Mbps
Upload speed achieved during the test was - 6.94Mbps
Details from my Plusnet Connection details
Telephone number:
xxxxxxxxxxx
Phone exchange:
BROADSTONE
Estimated line speed:
54Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-26 12:03:40
Current line speed:
53.4 Mb
Re: Fibre Unlimited Speed crashed from 50 Mbps to 12Mbps
13-02-2013 10:35 PM
What gateway are you on? http://usertools.plus.net/@gateway/
Ex-Broadband Service Manager
13-02-2013 10:37 PM
You are currently connected to the gateway known as ptw-ag04.
This is located in Telehouse West.
13-02-2013 11:01 PM
13-02-2013 11:20 PM
The test gives 45.57 Download and 8.25 upload.
When I click on further diagnosics it says this after running the tests.
You appear to have not logged on as speedtest@speedtest_domain. In order to run the next test you should login as speedtest@speedtest_domain.
Please wait while you are redirected..
I thinks thats because I cant do a further diagnostics test within an hour of a previous one ?
14-02-2013 9:48 AM
Quote from: DuncanM I thinks thats because I cant do a further diagnostics test within an hour of a previous one ?
It should have allowed you to run the test. Oh well, not to worry.
As things improved later in the evening there's a good chance your problem was caused by what's being discussed in the thread over here.
18-02-2013 9:14 PM
I am also running a Sam knows whitebox on my line if thats any help.
Download speed achieved during the test was - 24.68 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-48.42 Mbps .
IP Profile for your line is - 48.42 Mbps
Upload speed achieved during the test was - 6.73Mbps
You are currently connected to the gateway known as ptn-ag03.
This is located in Telehouse North.
[imgg]][/im
18-02-2013 9:18 PM
18-02-2013 9:25 PM
18-02-2013 9:27 PM
18-02-2013 10:31 PM
Download speedachieved during the test was - 44.81 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-48.42 Mbps .
Upload speed achieved during the test was - 8.02Mbps
Can / will this issue ever be fixed ? Its obviously something you are aware of. I havent checked my speed for a few weeks as I thought I was getting a steady 50 Mbps. I feel like I am checking it all the time now
19-02-2013 11:59 AM
19-02-2013 4:20 PM
Also, are you seeing any affects apart from the speed drop? I.e. lots of buffering on streaming, breaking up of VoIP, gaming lag etc.
Thanks.
19-02-2013 6:55 PM
Download speedachieved during the test was - 47.86 Mbps
You are currently connected to the gateway known as pcl-ag05
19-02-2013 6:59 PM
