Fibre To The Cabinet Available
goldenfibre
Fixes: 6
I had checked BT Wholesale Availability Checker today and was very surprise & pleased to hear that FTTC is now available to order as I had order Fibre Unlimited Product 80/20 via Plusnet member product change and choose my installation date next week as of 13th February on the AM slot. The estimated speed is 79.9Mb / 20.0Mb say BT.  Kiss Smiley
Can Plusnet staff check my order via BTW supplier to see if they had accepted my installation date of my choose on the 13/02/2014 (AM slot) if it was not possible, please let me know here or raise ticket via my member site.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Fibre To The Cabinet Available
I can can confirm that it's all booked in for 13/02/2014 - AM slot.
Chris Pettitt
Cloud Environments Engineer
goldenfibre
Fixes: 6
Wonderful news Chris. Finger cross it all goes well. Thanks. Wink
Might have to change your forum display name to 'goldenvdsl2' then? Wink
Call me 'w23'
goldenfibre
Fixes: 6
lol, very funny  Cheesy
goldenfibre
Fixes: 6
Am I correct when BT Engineer come next week to installing fibre, do I need to put plusnet username/password on BT Openreach Modem? Or no need for that, Just plug the ethernet cable from BTO modem to the back of my Netgear NGND3700v2 grey wan port that label say (fibre/cable) and change the setting on Netgear router to PPPoE from PPPoA and put plusnet username/password on it?
Fixes: 62
You do everything via the router - the modem only connects you to the exchange and the router looks after everything else
goldenfibre
Fixes: 6
Are the setting below for fibre on the router is correct? I had marked red mean ethernet plug into the back wan port for fibre.
Plusnet Staff
Plusnet Staff
Fixes: 5
That looks fine to me.
Chris Pettitt
goldenfibre
Fixes: 6
Getting exciting now Smiley  2 more days to go then my Fibre is here. I hope my order for Thursday 13th February AM slot still ok from BTWholesale order. Everything is now preparing and ready. Smiley
Fixes: 62
/* pessimism strikes
Waits for screams when the BT engineer doesn't turn up  Lips are sealed
goldenfibre
Fixes: 6
BT Engineer better be turn up! Hope BT won't let me down!
goldenfibre
Fixes: 6
Can plusnet staff please check my order with BT Wholesale to see if my fibre installation tomorrow AM slot is still go ahead and everything is plan ok. Thanks
Plusnet Staff
Plusnet Staff
Fixes: 5
Yep, it's still booked in and showing as normal.
Chris Pettitt
goldenfibre
Fixes: 6
Brill and thanks. I will post back tomorrow with the speed test from bt wholesale speed test. Smiley
