Fibre Speed
HNKS
Fibre Speed
Hello, I finally got fibre installed today however Im getting only half of the 72MB/s they said I would be able to get. Will the speed increase or is there something wrong?
I tried both wireless and wired and got 36MB/s. I am using the supplied router.
Fixes: 62
Re: Fibre Speed
Can you post the full results from the BT speedtest http://speedtest.btwholesale.com/ after selecting Further Diagnostics after the first run
Also the Current Line Speed from https://portal.plus.net/my.html?action=data_transfer_speed
HNKS
Re: Fibre Speed
Estimated line speed:
40Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-24 18:44:13
Current line speed:
37 Mb
Thats strange when I was signing up in said 72Mb for estimated line speed
Fixes: 62
Re: Fibre Speed
A guess - you have been provisioned on 40/10 instead of 80/20
A question did you sign up for Extra or Value
I ask because on Value you would be limited to 40/10 whereas on Extra it would have been 80/20
HNKS
Re: Fibre Speed
Im on the Unlimited Fibre Broadband package for £19.99. Im pretty sure thats upto 76Mb.
Fixes: 62
Re: Fibre Speed
It is indeed so something has gone wrong - there have been a few reports of that
I suggest waiting for it to be picked up here on Monday although you could try phoning in and you may be lucky and get someone who understands and can do something about it (the normal agent may not have the required access).
If you do ring in you should advise that the sync speeds as calculated from the BT speed test results are 40/10
HNKS
Re: Fibre Speed
Ok thanks. Ill probably give em a ring tomorrow or Monday.
Dingleberry
Re: Fibre Speed
Could you let me know how you get on with this?
I got connected a week ago, and have the same issue, apart from the sign up estimated 60mb for me.
HNKS
Re: Fibre Speed
Speed has gone up to 58mb which seems to be the limit according the the BT wholesale speedtest. Im quite happy that im getting almost all of that via wifi (56Mb). I heard some pretty bad stuff about the supplied router but its been good for me.
Hopefully ill get the 72Mb they promised.
Re: Fibre Speed
Sorry about that but glad it's sorted itself out - likewise hope it does improve. If there is anything we can do to help please let us know.
