Fibre Speed
thorpen
Fibre Speed
Had my fibre fitted this morning, but still only getting 1650kbps download speed - can someone help ?
jojopillo
Re: Fibre Speed
Hi thorpen,
I have now set your profile up for fibre speeds, you should see the increase shortly.
Jojo Smiley
thorpen
Re: Fibre Speed
Thanks JoJo - that worked earlier my download went up to 30mb!!  I had to unplug the router earlier and it is now only running at 9.5mb - please help !!!
KevinG
Re: Fibre Speed
I don't suppose you're on Value Fibre are you? If so you may have saved me a job last night ! (see Traffic Management thread)
thorpen
Re: Fibre Speed
It is still running at around 10mb - please can someone have a look ?
Re: Fibre Speed
Just tried running a check but it's been going over 15 minutes now, so I've passed your ticket over to one of our faults agents who'll update you shortly.
