Fibre Speed
- Fibre Speed
Fibre Speed
11-01-2013 7:35 PM
I tried both wireless and wired and got 36MB/s. I am using the supplied router.
Re: Fibre Speed
11-01-2013 8:07 PM
Also the Current Line Speed from https://portal.plus.net/my.html?action=data_transfer_speed
Re: Fibre Speed
11-01-2013 8:38 PM
40Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-24 18:44:13
Current line speed:
37 Mb
Thats strange when I was signing up in said 72Mb for estimated line speed
Re: Fibre Speed
11-01-2013 8:44 PM
A question did you sign up for Extra or Value
I ask because on Value you would be limited to 40/10 whereas on Extra it would have been 80/20
Re: Fibre Speed
11-01-2013 8:46 PM
Re: Fibre Speed
11-01-2013 8:51 PM
I suggest waiting for it to be picked up here on Monday although you could try phoning in and you may be lucky and get someone who understands and can do something about it (the normal agent may not have the required access).
If you do ring in you should advise that the sync speeds as calculated from the BT speed test results are 40/10
Re: Fibre Speed
11-01-2013 8:52 PM
Re: Fibre Speed
14-01-2013 2:55 AM
I got connected a week ago, and have the same issue, apart from the sign up estimated 60mb for me.
Re: Fibre Speed
15-01-2013 6:06 AM
Hopefully ill get the 72Mb they promised.
Re: Fibre Speed
17-01-2013 10:07 AM
Sorry about that but glad it's sorted itself out - likewise hope it does improve. If there is anything we can do to help please let us know.
