Fibre Speed slows then stops
Lovelythanks
Connection keeps dropping when buffering video... Starts off fast but then slows right down and eventually stops... Speed test shows the same pattern and result is less than half what it should be.
Resets on my hardware have proved fruitless
1 REPLY
petecov44
Re: Fibre Speed slows then stops
This might sound odd but try not to restart it anymore. Fibre DLM will drag the speed down although it will recover without the need to reboot again (in most cases) usually in 48-72 hours
And I guess raise a fault via http://faults.plus.net ?
