Fibre, Slow uploads
- Fibre, Slow uploads
Fibre, Slow uploads
28-12-2013 11:18 AM
Hi, I use a ftp server but when i upload, i cannot get faster than 1 mbps.
I use fibre and the speed test says I can get 8 mbps.
I have just heard about the pro add-on.
Will I need this?
Thanks.
Will I need this?
Thanks.
Message 1 of 9
(1,206 Views)
8 REPLIES 8
Re: Fibre, Slow uploads
29-12-2013 12:09 PM
What are the results of the BT Speedtester here: http://speedtest.btwholesale.com? (Please ensure you complete 'Further Diagnostics').
Message 2 of 9
(723 Views)
18-01-2014 2:33 PM
Hi, 40.38 mbps down
8.37 mbps upload
35.13 Ping Latency
I am uploading to Video Streaming sites but can only get 1 mbps.
I upgraded to include the pro add-on on the 17/01/14 but no difference. I do not know how long it takes to activate the pro add-on but no change in speed yet.
8.37 mbps upload
35.13 Ping Latency
Message 3 of 9
(723 Views)
18-01-2014 2:35 PM
are you sure that the upload to streaming sites is megabits per sec Mbps rather than megabytes per sec MBps
Pro addon has no effect at all on upload
Message 4 of 9
(723 Views)
18-01-2014 2:43 PM
Currently at 950-1000 kbps
I have installed the thinkbroad speed test program.
But I also did the bt wholesale speed test as recommend.
Message 5 of 9
(723 Views)
18-01-2014 2:57 PM
The speedtest didn't show any problems
I have a couple of thoughts
is your antivirus program scanning your uploads
Is this applicable http://community.plus.net/forum/index.php/topic,118234.0.html
Message 6 of 9
(723 Views)
18-01-2014 5:08 PM
I have disabled my eset protection, Antivirus & Firewall and then tried uploading with filezilla but no difference.
I have tried drag & drop and also flash uploads to the site but no speed difference also uploaded to a cloud backup server but no speed difference.
I am getting confused because the thinkbroad speedtester program, I installed is showing in the graph that I'm uploading at nearly 10 mbps but filezilla is saying 950-1000 kbps.
I am uploading a 350mb file and is taking 5-6 minutes.
I have included a screenshot of filezilla, speed is shown on the bottom panel.
The speedtester program.
I hope this helps.
I am uploading to Vidup site.
Thanks for your help.
I hope this helps.
Message 7 of 9
(723 Views)
18-01-2014 5:26 PM
This seems to be a confusion between MB/s (megabytes) and Mb/s (megabits)
Your image shows that you are uploading at 1.1MiB/s which (as there are 8 bits per byte) is 8.8Mb/s
Message 8 of 9
(723 Views)
18-01-2014 5:36 PM
I have to ask the question
Is what you are doing legal
Uploading a TV programme to a streaming site
Message 9 of 9
(723 Views)
