Fibre Router
Timalay
Fibre Router
Am I right in thinking, that this router will work with Plusnet Fibre.
goldenfibre
Fixes: 6
Re: Fibre Router
Yes, it will work along with BTO Modem connected to the Blue Lan Port as I just read manual instruction from download link here: http://www.tp-link.com/resources/document/Archer_C7_V1_User_Guide.pdf
Timalay
Re: Fibre Router
Brilliant, now ordered it.  Will mean if my 2nd Plusnet Fibre router fails, I won't have to sign a new contract, and get an increase of £2.50.  Tongue
goldenfibre
Fixes: 6
Re: Fibre Router
No matter if it plusnet router or not, you still locked in a 18 months contract as all fibre come with 18 months contract.
Timalay
Re: Fibre Router
Yes I know that.  What I am saying is, if this Plusnet Fibre router fails (which has done before, and is know for not being that good).  I don't have to sign a new contract (very near the end anyway), and get an increase of £2.50 for the broadband only price
Timalay
Re: Fibre Router
The Router this router today.  What configuration gubbings do I need to set it up?
Plusnet Alumni (retired) LinnPlusnet
Re: Fibre Router
Hi Timalay,
Please find below a link to a guide for setting up the FTTC connection with your own router (not supplied by Plusnet):
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml#fibreConnectionSe...
Hope this helps!
