Fibre Router
OshB5
Fibre Router
Hi
Will a Belkin  F7D4302 be ok to use on Fibre broardband? Cool
Regs
Re: Fibre Router
Looks like it should work, but reviews are poor.
jamesanstee
Re: Fibre Router
I tried and tested a belkin wireless N vision router and had nothing but problems with it and always dropping the connection belkin routers personal i'd stay clear of them Netgear and Linksys routers ive found to be most reliable .
OshB5
Re: Fibre Router
OK
Thanks for the quick reply. I will tell the guy im not interested. Tongue
Pity It was a good price as well at £17.70 inc postage LOL That said £17.50 for a door stop is still expensive  AngryLOL..
Back to the serching
Regards,
All4One
Re: Fibre Router
Just get a second hand BT Home Hub 3 for 0-5quid from ebay, search in your local area. What I did and super duper.
bill888
Seasoned Pro
Fixes: 24
Re: Fibre Router
fwiw, I read DD-WRT can be installed onto the F7D4301 dual band cable router.  These can be bought cheaply on eBay.  I think the 4301 has 4 gigabit ports, unlike the F7D4302 model.
Recent Amazon US reviews mention DD-WRT:
http://www.amazon.com/Belkin-Wireless-Play-Router-F7D4301/product-reviews/B003CJTNLS/ref=cm_cr_pr_to...
OshB5
Re: Fibre Router
All4One
How did you go with the BTHub 3? What do you have to do with it is there a propriety firmware you put in or does it need unlocking or something?
Regs
P.S. Im going to look into the F7D4301 and the DD-WRT can be installed onto theto see what can be done? Wink
Fixes: 12
Re: Fibre Router
All4One
Re: Fibre Router
OShB5 - It's fine, get the odd disconnect maybe once a week which is fine, but performs better than the PN box where I'd be experienced multiple drops a day.
Re: Fibre Router
1. Product name: BT Home Hub
2. Serial number: (redacted)
3. Firmware version: Software version 4.7.5.1.83.8.130.1.10 (Type A) Last updated 29/05/13
4. Board version: BT Hub 4A
5. ADSL uptime: 66 days, 07:46:17
Granted, this is a Hub 4, but performance on the Hub 3 I used previously was also very good.
