Fibre Powerline adapters.
- Re: Fibre Powerline adapters.
11-02-2013 3:59 PM
Hi all,
I got some free powerline adapters of my neighbour as they are getting rid of broadband (In their 80's) and moving into a retirement home so surplus to requirements.
I am connecting my BT OPR Modem to the powerline adapter and my BTHub3 Type B to the other end of the powerline adapter, this is so I can have my Mac Mini wired to the rooter. Has any1 experienced any problems is there a chance of massive speed drop?
Any comments greatly appreciated
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 9
(2,774 Views)
8 REPLIES 8
11-02-2013 4:03 PM
In my experience these tend to work pretty well.
Speed mostly depends on the wiring in your house and the capability of the adapters themselves.
Assuming that they are more than 100mbps and the wiring in your house is ok, you should be fine even with an 80mb fibre connection.
They are very easy to install however one thing to watch is that they can get quite warm so be careful if you have too many things near them. Also performance tends to be best if they are plugged straight into the wall rather than through an extension lead.
Hope that helps
Hope that helps
Message 2 of 9
(857 Views)
11-02-2013 4:09 PM
They are trialled talk talk adapters if that makes a difference
Message 3 of 9
(857 Views)
11-02-2013 4:28 PM
No idea, you need to know the speed of them.
Best way to find out is to check the speed of the connection once you have them plugged in. Not sure how to do that on a mac, but on a pc you can check the connection speed in task manager under the networking tab.
As I said, as long as its showing a speed faster than your fibre connection, then you wont be throttling your downloads.
Message 4 of 9
(857 Views)
11-02-2013 4:36 PM
I have VM windows 7 will find on there. ATM it showing download speeds of 30Mbits but probably due to internal wiring. At least its in the place i want it in!
Message 5 of 9
(857 Views)
11-02-2013 4:45 PM
They may only be 54mbps units then.
Im assuming that you are on 80mb fibre so obviously if you are only getting 30mbps through the powerlines this will effect the speed of your connection.
Up to you now, you can either try some faster powerline adapters...
like these:
http://www.amazon.co.uk/TP-Link-PA411KIT-AV500-Powerline-Adapter/dp/B0084Y9N3O/ref=sr_1_4?s=computer...
Or if its fast enough for what you want, then leave it as it is, as at least its working!
like these:
Message 6 of 9
(857 Views)
11-02-2013 6:03 PM
They are now soaring up to 50mbits down 15mbits up according to www.speedtest.net so just a 10mbit drop (download)
Message 7 of 9
(857 Views)
11-02-2013 6:38 PM
Why not connect them to your HH lan and Mac mini, rather than between BTOR modem and HH wan. At least that way your not limiting your xDSL speeds.
Message 8 of 9
(857 Views)
11-02-2013 7:03 PM
I have a switch in the same room as the BT hub and Mac mini so I have mac mini conected to LAN1 and switch via long ethernet CAT6 cable on LAn2 which is on other side of the room
dick:quote
dick:quote
Message 9 of 9
(857 Views)
