Fibre Optic Capped at 4MB
ethancarne1
Today I got fibre optic installed in my home the engineer  said it was capped at 4MB and I needed to contact you.
Ethan
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Fibre Optic Capped at 4MB
Hi Ethan,
Sorry for the capping. I've updated your Speed Profile, that should take a short time to kick in for you.
Chris Pettitt
Cloud Environments Engineer
ethancarne1
Hi Chris,
Thanks very much. I'll keep you informed if any problems.
Kind regards
Ethan.
