Fibre Install
- Fibre Install
Fibre Install
11-03-2014 6:02 PM
I am due to have fibre broadband installed tomorrow (12th March) during the AM however I have not received a fibre router as of yet. Could someone have a look for me and advise me that everything is still going as planned?
Cheers,
James.
Cheers,
James.
Message 1 of 5
(700 Views)
4 REPLIES 4
Re: Fibre Install
11-03-2014 7:05 PM
hmm really should have received it if your install is tomorrow although it has been known to turn up on the day of install.
have you checked that the router has been despatched you can do so via your Members centre under account, pick connection settings and then order tracker and it should have a green tick next to hardware delivery if the router has been sent.
if it doesn't then something is up, Personally i would phone PN and check you don't want to be waiting tomorrow for a engineer visit that may not be happening
Message 2 of 5
(407 Views)
Re: Fibre Install
12-03-2014 12:11 PM
Hi jamesje2014,
Something doesn't look right. I'm just getting this picked up for you now.
We'll be in touch shortly when we know a bit more info on this for you.
Message 3 of 5
(407 Views)
Re: Fibre Install
12-03-2014 12:15 PM
No problem Chris. Thanks for keeping me posted.
Message 4 of 5
(407 Views)
Re: Fibre Install
12-03-2014 1:35 PM
Our Provisioning Team have tried to get in touch with you but there was no answer.
We're still working on this, but if you have access to the internet in the meantime, updates will be available on Ticket: 82598763 ( http://contactus.plus.net )
Message 5 of 5
(407 Views)
