Fibre Install: What to know & expect
- Re: Fibre Install: What to know & expect
09-07-2012 11:56 AM
Finally got permission to get fibre installed
Just before I order the fibre package, few things I want to know:
Extension Cabiling: Is the cable just a back to back RJ11 taken from the master socket to the modem? Or can an engineer fit a box allowing the RJ11 to be terminated at a box nearer to the OR modems location and then a short cable from the termination point to the modem?
Router: Are Plusnet supplying technicolour ones or Netgears now? (Going to get a PN one just incase my own router fails whilst on FTTC).
80/20 Trial: When looking at BT ADSL Checker, it just tells me I can get 40/6.5mbps, even though the cab is literally 30-50m down the road. Checking everyone on the same PCP, they get the same kind of estimates, noting above 40meg. Can I still go on the trial?
Plus, is there anything specific to know about the install and what to do? (IE: What to have ready, dont punch the guy in the face if he's being difficult or very late, do I need to unplug ADSL/Phone for the whole install day etc)
Cheers!
Cheers!
Message 1 of 7
(1,760 Views)
6 REPLIES 6
09-07-2012 5:27 PM
Hi Amanha,
Yes it's a RJ11 cable up to 30M long. They're only supposed to pin it to skirting boards/door frames but I've heard of them relocating the socket (I presume that's only when it's been easier to do that)
Yes, we supply the Technicolor TG582n and it's flashed for fibre.
Once you're up and running, if you get the full 40Mbps then we'll put you on the trial. It's only people who don't reach 40 in the first place that are not worth putting on it.
It's a lot quicker than it used to be, so I don't see you being without your phone for too long.
Jojo
Quote from: Amanha Extension Cabiling: Is the cable just a back to back RJ11 taken from the master socket to the modem? Or can an engineer fit a box allowing the RJ11 to be terminated at a box nearer to the OR modems location and then a short cable from the termination point to the modem?
Quote from: Amanha Router: Are Plusnet supplying technicolour ones or Netgears now?
Quote from: Amanha 80/20 Trial: When looking at BT ADSL Checker, it just tells me I can get 40/6.5mbps, even though the cab is literally 30-50m down the road. Checking everyone on the same PCP, they get the same kind of estimates, noting above 40meg. Can I still go on the trial?
Quote from: Amanha Plus, is there anything specific to know about the install and what to do? (IE: What to have ready, dont punch the guy in the face if he's being difficult or very late, do I need to unplug ADSL/Phone for the whole install day etc)
Jojo
Message 2 of 7
(635 Views)
10-07-2012 5:40 PM
Aha awesome!
One thing though, under the "account summary" thingybob, it shows I have Extra 60GB, which was ordered yesterday! The funny thing is that I ordered fibre, not my current ADSL Package.
But the order for the Fibre router is there, so Im thinking it could just be a error on PN systems?
Is this alright or should I be worried?
Cheers.
Quote 09/07/2012 // BP01486268 // Extra with included 60GB bandwidth // £11.49(monthly) // Complete
Cheers.
Message 3 of 7
(635 Views)
11-07-2012 10:06 AM
Message 4 of 7
(635 Views)
11-07-2012 10:26 AM
Just to follow up, we do have an appointment booked for between 08:00 and 13:00 on the 17th.
Apologies as you should have received an SMS to inform you of this, further checks reveal that we have an issue with that at the moment so it's being looked into on problem investigation: 71065
PS I'll get this updated on your account too.
Adam
Adam
Message 5 of 7
(635 Views)
11-07-2012 11:34 AM
Cheers Adam, thats awesome.
I shall be looking foward to fibre - Was slightly alarmed at what service notes stated!
Message 6 of 7
(635 Views)
11-07-2012 2:04 PM
Message 7 of 7
(635 Views)
