Fibre BB is slowing down.
- Fibre BB is slowing down.
- « Previous
- Next »
Re: Fibre BB is slowing down.
05-02-2014 3:10 PM
Liking the look of that graph
Message 31 of 39
(423 Views)
05-02-2014 4:27 PM
hmm. there is some packet loss on there now?
Kelly Dorset
Ex-Broadband Service Manager
Message 32 of 39
(423 Views)
05-02-2014 4:34 PM
The connection is dropping a little:
<img src="http://community.plus.net/visualradius/generated/image1391618025680.png"/>
I'll keep an eye on things to see if it settles down.
Message 33 of 39
(423 Views)
05-02-2014 5:11 PM
Thanks Chris/ Kelly. Those drops may have been caused by me doing "soft" resets on the router. I'll leave it alone.
Message 34 of 39
(423 Views)
06-02-2014 9:22 AM
Message 35 of 39
(423 Views)
06-02-2014 9:53 AM
The Engineer would have turnt interleaving off during the reset, them pings look about right. Also depending on what gateway you are on also.
Some gateways give you a ping of 10-14ms, others give you 14-20ms. I find PTN-ag03 gives me the lowest ping to bbc (Around 10ms)
Message 36 of 39
(423 Views)
06-02-2014 10:49 AM
I can confirm that Interleaving is Off.
Profile: 33M-67M Downstream, Interleaving Off - 8M-17M Upstream, Interleaving Off
Message 37 of 39
(423 Views)
06-02-2014 11:23 AM
If that was for me Chris then VMT.
Message 38 of 39
(423 Views)
06-02-2014 11:24 AM
Yep that was for you
Message 39 of 39
(423 Views)
- « Previous
- Next »
