Fibers BT Wholesale Page Redirection
abbiati50
good day
I experience Fibers BT Wholesale Page Redirection; on my fibers connection often; I am the only one or is a PN issue ?
regards
ray
Re: Fibers BT Wholesale Page Redirection
Are you logged in with username@plusdsl.net ?
Are you specifying your own DNS servers in your connection settings or using PlusNet's automatically assigned?
Fixes: 165
Are you by any chance using your own router, and is that router a Netgear?
 Chris Parr
 Plusnet Staff
abbiati50
Hi Chris;
i use netgear router to get wireless which is attached to the bt white modem installed by bt;
No - i do not use any dns; router is setup to automatic detection.
yes i use my username@plusdsl.net
thanks for help
ray
abbiati50
Quote from: AndyH
I have changed to the specified own dns as in PN settings panel; rebooted router and look is working.
will that make a difference ?
Fixes: 165
Yep, that should fix it. When we were sending Netgear routers for Fibre back when we first started offering it, we saw quite a few of the same issues. However we made a change (can't remember when it was) that resolved the majority of them.
 Chris Parr
 Plusnet Staff
abbiati50
thank you !  Cheesy
