Fibers BT Wholesale Page Redirection
- Re: Fibers BT Wholesale Page Redirection
05-12-2013 8:29 AM
good day
I experience Fibers BT Wholesale Page Redirection; on my fibers connection often; I am the only one or is a PN issue ?
regards
ray
regards
ray
Message 1 of 7
(1,069 Views)
6 REPLIES 6
05-12-2013 9:36 AM
Are you logged in with username@plusdsl.net ?
Are you specifying your own DNS servers in your connection settings or using PlusNet's automatically assigned?
Message 2 of 7
(553 Views)
05-12-2013 1:56 PM
Are you by any chance using your own router, and is that router a Netgear?
Message 3 of 7
(553 Views)
05-12-2013 3:50 PM
Hi Chris;
i use netgear router to get wireless which is attached to the bt white modem installed by bt;
No - i do not use any dns; router is setup to automatic detection.
yes i use my username@plusdsl.net
thanks for help
ray
thanks for help
ray
Message 4 of 7
(553 Views)
05-12-2013 4:16 PM
Quote from: AndyH Are you logged in with username@plusdsl.net ?
I have changed to the specified own dns as in PN settings panel; rebooted router and look is working.
will that make a difference ?
Message 5 of 7
(553 Views)
05-12-2013 4:17 PM
Yep, that should fix it. When we were sending Netgear routers for Fibre back when we first started offering it, we saw quite a few of the same issues. However we made a change (can't remember when it was) that resolved the majority of them.
Message 6 of 7
(553 Views)
05-12-2013 4:21 PM
thank you !
Message 7 of 7
(553 Views)
